troubleshooting codes help
Old Apr 20, 2008 | 02:26 AM
HAZE's Avatar
Default troubleshooting codes help
hey guys, don't like to cross post but my thread isn't getting any more response over in tuning and i thought there might be a few people who don't look there much.
codes are;
P0102- maf - replaced maf - still have code - have battery voltage on pink wire, 5v on signal wire- continuity on ground- 2300- 2500 hz @ idle - 5v on iat signal - continuity on ground - no intake leaks that i can find
P0443 - purge solenoid - replaced solenoid - still have code - have power at plug.
P0449 - vent solenoid - have not replaced
all evap lines are sound, no leaks that i can find, canister seems intact, replaced gas cap,
anyone know of a relationship between these three codes ? i was thinking vacuum leak but i can't find any ?
i have 19 lbs vacuum per my boost gauge [ whipple compressor, 8.1 marine inj's, nelson tune, 5psi pulley on right now] develops full boost pressure.
truck seems to idle fine, runs good, had some trans jerks when it coded the first time [ all three codes at the same time] no additional codes set.
any ideas are welcome, after i pull the vent solenoid and check it out my next option is the dealer since i'm about out of things to check.
thanks, e
Old Apr 27, 2008 | 05:04 AM
HAZE's Avatar
got it, see solution here
https://www.performancetrucks.net/fo...d.php?t=415733
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
muncie21
Sep 7, 2015 09:55 PM
