Trouble Starting In Morning
Old Dec 18, 2004 | 12:09 PM
Question Trouble Starting In Morning
I Got A 1996 Chevy Silverado With 100 Thousand Miles On It Jus Did A Full Tune Up On It And It Jus Has Trouble Starting In The Morning .IT WILL CRANK OVER 3 TO 4 TIME B4 IT STARTS. If Any 1 Has Any Suggestions Please Let Me Know Thanx.
Old Dec 18, 2004 | 02:47 PM
chevymec's Avatar
Sounds like the check valve in the pump ot the regulator is leaking. Does it only have trouble when it sits for a while?
Old Dec 18, 2004 | 04:16 PM
when you turn the key to the on position can you hear the fuel pump run for a couple secs?
if not its prob the fuel pump relay....
the pump wont turn on until there's some oil pressure if its bad
if it does turn on initially see above
Old Dec 18, 2004 | 07:50 PM
Default Help!!!!!!!hard starting 00' 5.3
My wifes wifes suburban is having a similar problem.
Has 60k miles on it. Im on my second fuel pump (has about 30,000 miles on it)
Anyway when you the key you first hear the pump run, then when you start to crank it, it really takes a while to start. then a puff of smoke comes out the exhaust. Its like it not getting enough fuel.
Any suggestions???????? Ist there a one way check valve some where in the system between the pump in the tank and the injectors?
Old Dec 19, 2004 | 12:09 PM
Lightbulb
yea it only does that when i let it sit over night .
Old Dec 19, 2004 | 12:11 PM
yea i let the fuel pump run first then i start it but it just cranks but when it starts it does not smoke.
Old Dec 19, 2004 | 12:46 PM
wrencher's Avatar
wrencher
This is screaming fuel pump problem, but has the fuel filter been changed. The pumps are notorious for failure, seen many sometimes due to no filter changes. They act up cold mostly, not able to muster enough pressure/volume. I believe the 96 is the entire tank module to replace the pump any way. Use delco pump also< higly suggested. If your a repeat failure pump, empty & clean the gas tank out. Then start with fresh fuel. Use the old gas in something else. Might be a good idea to do this w/a 100K'er anyway.
Old Dec 20, 2004 | 11:33 AM
Thumbs up
The fuel filter was changed recently and the pump was never changed. So yeah it is time to change the pump.
Old Dec 20, 2004 | 11:36 AM
Talking
Yeah its worse when it sits for a while. I'm changing the fuel filter today.
cleaning the MAf and the TB. I'll let ya know.
Merry Christmas
Old Dec 20, 2004 | 02:18 PM
chevymec's Avatar
Also check out the plug at the sending unit. They were bad in the earlier years about getting hot and burning wires and connectors.
