track tomorrow
Old Sep 2, 2005 | 12:01 AM
parish8's Avatar
single digit dreamer
Default track tomorrow
well? what do you all think?
i am not going to strip it down so i will probably be 200-300lb's heavier than when i ran my best run before. added roll bar, hitch, sway bar, passenger seat, gate.
added the 4 nittos and will be adding up to 200hp from my best run before. on my best run i only cut a 1.78 60', i am going to try and knock .2 off of that.
will the motor take it? will the driveline come apart? will it run 9's?
i will need quite a few runs to dial it in so if they are packed i might not have time to dial it in and make my best run.
Old Sep 2, 2005 | 12:34 AM
TravisH's Avatar
sweet dude, I hope everything stays together for ya! breaking into the 9's would be sick as heck in that truck.
Old Sep 2, 2005 | 12:57 AM
Mr. Sandog's Avatar
Too bad you can't come to our private track day in Fontana on September 23rd....I'd give up my spot just to see your truck run. For these private events there are 80 vehicles only and you can get as many runs in as you want....12-15, or more if you want.
You sure you don't want to come visit us? You could stop in at CMS in Vegas on the way over...
Old Sep 2, 2005 | 01:16 AM
02sierraz71_5.3's Avatar
I think with the added traction on all 4 you could see a 1.5 or lower 60'. I believe in ya from the last setup it definately looks good for a 9 sec pass as long as nothing breaks, my money is on the rear end or front diff going though especially if you start cutting consistent 1.5ish 60's
good luck man cant wait to see the vid
are you gonna do a 2wd burnout before staging? wonder how your gonna get the fronts heated
Old Sep 2, 2005 | 05:38 AM
ap2002's Avatar
good luck on the track, hope nothing breaks..... we are all ready to see some videos and times!!!
Old Sep 2, 2005 | 05:51 AM
wkdivr's Avatar
Good luck at the track. Are you still going to do the Hot Rod Drag Week?
Old Sep 2, 2005 | 06:01 AM
moregrip's Avatar
what a rush!
Best of luck! it will be interesting to see how the 4 wheel launch is affected by the sticky rubber
Old Sep 2, 2005 | 06:43 AM
parish8's Avatar
we are doing drag week if it makes it thru tonight, i am going to try cuting a high 1.5 without heating the dr's at all.
Old Sep 2, 2005 | 07:36 AM
JRsilverado's Avatar
Good Luck I hope your drive train holds up.
Old Sep 2, 2005 | 08:48 AM
slowec's Avatar
9's or bust. Good luck. I did a 4wheel burnout in my subie .Come to think of it. Maybe thats why my tranny exploded after 7k of driving Who would have thought, z71 is a go fast mod
