Towing
Old Apr 11, 2006 | 11:44 PM
Default Towing
im curious to see if anyone has towed a small encolsed trailer (20-24) ft with a car in it using a suburban or a tahoe with a 5.3?
my suburban has a 5.3 and im curious to see how bad it would be if i tried pulling a small enclosed with my camaro in it.... my camaro weigh's about 3100lbs and it would only be for about 60 miles or so with no hills what so ever ..... mostly highway which im sure is fine but what about stop lights?
thanks in adavnce
Old Apr 12, 2006 | 12:13 AM
thunder550's Avatar
High on diesel fumes
You should be fine. It won't be a power monster but it's not too bad. There's some good low-end torque available to get things moving. I have towed a 6000 lb boat with a stock 2000 Suburban and it feels fine until you get to a big hill, then I have to leave it in 2nd to keep freeway speed. You probably won't be able to get away with using OD unless coasting downhill, but it will do fine pulling in 3rd.
Old Apr 12, 2006 | 12:34 AM
Bo185's Avatar
I think it would do fine. I would look at getting some air over load bags for the rear. My buddys tahoe seems like it has soft springs in back. And if he puts a load on it it hits the ground.
Old Apr 12, 2006 | 01:26 AM
jagjohn2000's Avatar
5.3 suburban pulls a 7200 camper fine in third.
Old Apr 12, 2006 | 05:04 AM
smooth_addictions's Avatar
i pulled a 64 impala on a 1,500 lb. trailer for over 2,000 miles no probs. watch the tranny though.
Old Apr 12, 2006 | 05:11 AM
NoChrome's Avatar
I would definately get a cooler if you dont already have one, and a set of trailer brakes, if you will be doing alot of light to light driving. Do you have 4.10's or the 3.73's
Old Apr 12, 2006 | 07:23 AM
joehawkz71's Avatar
I have towed 2 cars on the same trailer with my truck....the truck handeled it like know ones busniess....i did have my 6" suspension lift in and 3" body and 35" tires in too. and it was the stock 3.73 gears. they only think that happened is that i blew my rear end.. do to trying ot race some ricer on his way home from the track with both the cars on the trailer....
onyourls1 you should be fine towing that camaro...
Old Apr 12, 2006 | 10:47 AM
thanks a ton guys, im a frequent ls1tech reader and its nice to see a site for my truck too..... not sure what my rear end ratio is, yeah i would tow in 3rd and seeing how its in IL there are no hills. anything i can do to the rear suspension to help tow a load like that? but at the same time i dont want to change the everyday ride.
Old Apr 12, 2006 | 02:55 PM
NoChrome's Avatar
helper springs from summit, jegs, or jc whitney.
calsdad
Jun 14, 2023 11:07 PM
AdaMax
May 16, 2016 11:35 PM
cheyenne383
Nov 13, 2015 09:24 AM
SWINGRRRR
Sep 3, 2015 07:49 PM
