Tire pressure sensors
Where's the Beef?
I have 4 of them from an 07 that are new and have 25 mi on them. I'm wanting to sale the sensors but was wanting to know if I unscrew them from the valve stem or does the entire stem need removed?
Entire stem would be difficult
If your sensors have the aluminum valve stem, then you'll have to remove the entire sensor. But if the valve stem is black rubber, you can simply unscrew the stem and use only the sensor. But keep in mind, that if you sell only the sensor, whoever buys will have to purchase the $8.00 each, removable valve stems to make the package work.
If you were to go to a dealership, the sensors run about $56.00
Where's the Beef?
Thank you very much. that was quite helpful. I have the rubber ones and wouldn't mind taking them out to save someone some money on the stems. Should be able to cut someone a nice deal on them if they need a set.
Hopefully i can get them removed this friday.
That's each right?
That's each right?
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
