Tire pressure ?
Old Dec 13, 2004 | 09:16 AM
storm5.3's Avatar
13 Second Truck Club
Default Tire pressure ?
Ok, simple ? What do you set the tire pressure to and why ? Door placard says 35psi but that was for O.E.M. tire. Max pressure on new tires says 44psi. so which one ???
Zed
P.S. This is normal everyday cruising down the highway.
Old Dec 13, 2004 | 10:26 AM
marc_w's Avatar
I always shoot for around the door spec, and adjust from there. My door says 30psi.
I normally run 32-33F, 30R.
I run 32-33F, 35-40R when towing.
Old Dec 13, 2004 | 10:29 AM
unklej's Avatar
I run 35psi all around.
Old Dec 13, 2004 | 10:32 AM
FILE's Avatar
I normally run 32-35 all around.
Old Dec 13, 2004 | 11:06 AM
storm5.3's Avatar
Ok, and now for the why part. Somehow I remember someone saying to go w/ the max press. on the tire. Why or why not ???
Zed
Old Dec 13, 2004 | 12:11 PM
marc_w's Avatar
I can chime in on why I hear 'not' to do that:
GM finds a good general pressure for all around performance with handling, and braking, while still providing good tire wear, ride, and fuel economy. Supposedly ABS and the brake bias is setup for the recommended pressure.
If you run the max pressure, you'll have a smaller contact patch, which effects all of the above. Some it may help, like fuel economy - but others it will hurt.
There are fomulas on the net that will help you fine-tune your tire pressures based off of your vehicles weight bias. I didn't like the way my front tires looked soft with the recommended 30psi, which is why I run a little more up front. I've been meaning to get around to weighing my truck and calculating out some pressures.
Oobray
Jun 13, 2022 03:38 AM
thunder550
Oct 8, 2015 04:53 PM
Verz
Aug 21, 2015 06:40 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
