tire options for 17's on a 4/6
Old Nov 1, 2007 | 07:06 PM
blank260's Avatar
Default tire options for 17's on a 4/6
I have 245/70/17 on my stock tires and am gonna go ahead and get a new set of tires this weekend. Looking for something a little wider that won't rub with my 4/6 on their. What will fit comfortably?
Old Nov 1, 2007 | 07:11 PM
nightrunner's Avatar
Mr. Obvious
i dont know how to calculate this type of thing but is this on stock wheels?
Old Nov 1, 2007 | 07:24 PM
blank260's Avatar
yea its on a stock wheel, i would like to go with like a 275/60 tire but not sure if it'll be compatible with the 4/6
Old Nov 1, 2007 | 07:25 PM
Mr. Obvious
im pretty sure not but maybe a 275/55 would work?
a 275/50 is very close to a 275/35/R20, which is what 02bluestepside has on his 4/6'd truck
Old Nov 1, 2007 | 07:30 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
I used 255/60/17s on my 4/6 with no issues
Old Nov 1, 2007 | 07:40 PM
blank260's Avatar
what about a 265/65?
Old Nov 1, 2007 | 07:44 PM
Mr. Obvious
http://www.intercotire.com/site60.php
gives height, width, and sidewall height
like i said i know for sure that a 275/35/R20 will work on a 4/6 and i know a 255/45R20 will work so you might could work off of those
Old Nov 2, 2007 | 01:36 PM
slow.8's Avatar
ive got 275/60/17`s with a 3/5 drop. they rub just a bit up front at full lock in either direction.and the passenger side front grabs the fender on some bumps. im not running stock rims though.
Old Nov 2, 2007 | 01:49 PM
flossinon_24s's Avatar
go with a 245 70 17. they are factory size and can be found pretty cheap as takeoffs
Old Nov 2, 2007 | 04:55 PM
BBLS1's Avatar
I Like Gold!!!
There is no way that a 275/60 should rub!! Buddy of mine runs that exact setup on a 5/8 drop with no issues. I woud go with a 275/55 or 50 series. If you have a 4/6 drop the 275/50 would more sporty then a 60 series. The 60 is to tall(i think).
