Tie rods ,ball joint or pit mans fix?
Old Aug 23, 2013 | 12:39 PM
40series's Avatar
Default Tie rods ,ball joint or pit mans fix?
I got play laterally i mean from left right ( passenger driver) direction on the tire --- i think this is signs of tie rod fail
is this correct?
Old Aug 23, 2013 | 01:12 PM
RacinRust's Avatar
Truck description? 2 or 4 WD ?
Old Aug 23, 2013 | 01:13 PM
Gordy M's Avatar
Jack up the front end an grab the front wheel at 3 & 9. Move it left/right and if the tie rods are bad you will feel the movement. When they first start going you sometimes need someone to look at the tie rod because the movement is very minor. If that is not the problem, use the jack handle and place it under the front wheel and use it to lift it up and then back down. If there is play in the wheel doing this it is a ball joint.
Old Aug 23, 2013 | 01:32 PM
40series's Avatar
Default yep its 3 n 9
yep its 3 n 9 movement
do i replace the tie rod end or the whole rod as this is expensive to me
ls1curt
Jan 5, 2016 11:33 AM
Tydriver
45
Oct 23, 2015 09:19 PM
iregret
Sep 7, 2015 01:20 PM
xerox17
Sep 5, 2015 01:23 PM
hackrst
Sep 2, 2015 05:27 PM
