Tie Rods..............
#53
OK- everything's rolling along, even got the right pitman arm, the 4 spline. Thing is I get it to seat then I put the nut on the stud and it's tougher than a MOFOI wonder if I'm not doing something right........
#54
Did you mess up the threads getting it off?
Are you saying its tough to thread the nut on without making contact with the arm, or is it tough to snug the arm up? Aftermarket arms don't seem to go as high up on the threads as OEM did. I could barely get the washer and nut both on there
#55
Threads are good, I wonder if the splines might not be lined up- gonna check that. Seemed to start going on nice and good, tap seated it a bit so it would stay up there started to tighten, got tighter pretty quick then that was it. I'll snap a pic.........
Thanks
Thanks
