Thumping or Knock in Your Steering Wheel?
Old Jun 11, 2007 | 02:16 PM
  #21
Mark Johnson's Avatar
I'm starting to think that my steering box is going south. What are the symtoms............
Old Jun 11, 2007 | 03:48 PM
  #22
dyers98's Avatar
I thought it felt like a weak tie-rod? You just feel a thumping in the steering wheel along with an irritating 'loose' sound when the wheel is even slightly turned when you are moving.
Old Jun 11, 2007 | 03:55 PM
  #23
I posted the bulletin earlier in this thread, and it's got the symptoms in it.
Old Jun 11, 2007 | 04:01 PM
  #24
jconner111's Avatar
(or you can disconnect it and run the shaft down and re-install (like we did at the dealer). works for a while till you need a new grease plug kit. Also be sure to tighten the (4) bolts on the frame connector (goes across the bottom from 1 side to the other) these were undercoated before install and tend to pop at parking lot turn speeds.
Old Jun 11, 2007 | 04:05 PM
  #25
04BlackGmc's Avatar
10 Second Club
looks like i might be going in for mine..soon.
im on my 4th
Old Jun 12, 2007 | 09:19 AM
  #26
im on my 4th
..lol...you sound like me! I've replaced my shaft twice (before the new design)...and I've re-lubed the damn thing at least 6 times....lol.
Old Jun 12, 2007 | 11:37 PM
  #27
04BlackGmc's Avatar
10 Second Club
Yea, i need to go in but too lazy,btw those coolent tablets worked like a charm man!
Old Jun 13, 2007 | 10:39 AM
  #28
Good deal....I'm glad they worked! I'd say I got 3 packs floating around in mine!...lol..
Old Jul 15, 2007 | 12:48 PM
  #29
GTOsRamairSilverado's Avatar
i have a thuming sound comming from the front of my truck but i cant really say that i feel it in the steering wheel. i want to fix this problem, but i dont want to buy the new shaft if thats not going to be the problem. i want to try to grease the shaft that it has right now to see if the thumping sound stops. if it does then i will buy the new shaft. but my question is where do i lube the existing shaft at and will any kind of grease work?
Old Jul 16, 2007 | 08:26 AM
  #30
Hey friend the grease kit you want is Part# 26098419...you can grab them at your local GM Dealer. They have the instrruction sheet inside with the kit, do it's a breeze. If you can't find one....PM me and I'll send you one.
