Thrown Belt?!?!?!?!?!?
Old 11-07-2010, 08:34 PM
Gadgetized's Avatar
I'm with Terravast4, get a new belt. That belt might be a good spare to limp you home if you ever break the new one. How did you check the alignment of the pulleys? If you eyed it up they could still be off. I would run a straight edge across each pulley, and make sure it stays parallel with the belt. The pulley could be in the right position, but cocked a little bit. How long have you been running the new alternator? Check to make sure all the pulleys turn freely by hand too.
Old 11-07-2010, 08:39 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Well I put about a 1000 miles on this new setup with tons of 6600rpm shift points dialing in my shifts and it didnt throw the belt. It did start after I installed the alternator and new belt as far as the squeeking is concerned. I had a good gates belt before hand but bought a cheapy to get me through til the blwoer goes on. I dont really see how the alternator could be out of alignment since the pins on the accessorie bracket center the alternator and the alternator is brand new.
Old 11-07-2010, 11:01 PM
PT's Slowest Truck
budhayes3's Avatar
One of the pulleys seizing up? Or just a cheapie belt that's a tad too long...
Old 11-08-2010, 05:15 PM
1slow01Z71's Avatar
THink its just the cheapy belt since I think I paid all of 2X bucks for it, dont really remember just told em to give me the cheapest ya got.
Old 11-09-2010, 01:19 PM
TXsilverado's Avatar
i cant keep an AC belt on my truck lately. new tensioner and belt, and it will chunk it every time.
Old 11-09-2010, 04:03 PM
48548's Avatar
What is the part number for the HD tensioner? Also is there two as I have two belts one for the accessories and one for the ac. I just bought new gates belts for 80 dollars.
Old 11-09-2010, 04:07 PM
1slow01Z71's Avatar
If youre NA Id spring for the Katech tensioner, its nice and everyone seems to have good luck with them. Id love to have one for my truck but theyre arent compatible with blowers.
Old 11-09-2010, 06:19 PM
PT's Slowest Truck
budhayes3's Avatar
I plan on getting one as soon as I get the dough for it...my belt squeals when my lockup clutch hits...
Old 11-23-2010, 04:35 PM
1slow01Z71's Avatar
Starting to lean towards it just being a cheapo belt. The belt is squeeking now too, I sprayed some lithium grease on it and the squeek went away. So a belt with less than 1K on it is stretching and squeeking already. So dont buy cheap belts
Old 11-23-2010, 06:08 PM
Destroyer of Transmissions
1SlowHoe's Avatar
I had an issue like this. I finally figured it out after a couple of belts and a couple of tensiors were destroyed. Damn crank bolt had backed out and the balancer would wobble with quick throttle and release. I found out when I went to put the belt on..again...and the balance fell off the crank into my hand :o
Lock tite and an ARP crank bolt, no more issue.
Quick Reply: Thrown Belt?!?!?!?!?!?
