Is there any performance diff in the 5.3 LMG vs LY5
Old 01-22-2008, 07:11 AM
Default Is there any performance diff in the 5.3 LMG vs LY5
There are 2 5.3L choices when specing a 2008 Chevy Silverado RC. Is there a downside to the one that runs ethanol?
Engine,
Vortec 5.3L V8 SFI FlexFuel, with Active Fuel Management, capable of running on unleaded or up to 85% ethanol, (315 hp [234.9 kW] @ 5200 rpm, 338 lb-ft of torque [456.3 N-m] @ 4400 rpm), iron block (LMG)
Engine,
Vortec 5.3L V8 SFI, with Active Fuel Management (315 hp [234.9 kW] @ 5200 rpm, 338 lb-ft of torque [456.3 N-m] @ 4400 rpm), iron block (LY5)
I am toying with the idea of selling my CTS-V and getting a RC and pumping it up to 420 or so RWHP. Supercharged of course.
Old 01-22-2008, 12:58 PM
Baltimore Whore
Mangled03gmc's Avatar
I believe the only difference is in the tuning, the flex fuel has different injectors. Other then that I think there the same..
John
Old 01-22-2008, 01:56 PM
TOTM: November '07
explorer5.0's Avatar
Go with the flex fuel truck because the stock injectors will support your power goals.
Old 01-22-2008, 02:14 PM
KevinF56's Avatar
yeah i've heard the flex fuel engines have bigger injectors.
Old 01-22-2008, 04:04 PM
Bo185's Avatar
Plus the E85 loves BOOST!
Old 01-22-2008, 04:38 PM
TOTM: November '07
But if he uses E85 with boost, he will have to upgrade injectors...
Old 01-22-2008, 07:16 PM
JB1
JB1's Avatar
why is that?....explain
Old 01-22-2008, 07:26 PM
blownerator
BlownChevy's Avatar
I would not use the Flex Fuel truck for FI....I would get the gas motor.
Old 01-22-2008, 07:53 PM
Bo185's Avatar
Why not because of the dual tune or what? Larger injectors and larger pump.
Old 01-22-2008, 07:55 PM
TOTM: November '07
E85 requires more fuel flow. Those 38(?) lb injectors that the flex fuel trucks have will support his power goals with gasoline; but to make that same power on E85, he will likely need 50-60lb injectors.
Quick Reply: Is there any performance diff in the 5.3 LMG vs LY5
