Is there any performance diff in the 5.3 LMG vs LY5
Old 01-23-2008, 08:12 AM
zippy's Avatar
I personally preferr the E85 setup. This will allow you to run E85 with boost if you want to and still have the pcm pick that up. The stock pump on the E85 vehicles commonly are big enough to flow all of the fuel you're going to need for a boosted 5.3L. A TVS1900 on that engine would be bad ***. As for using the stock injectors under boost, even the 38's on the E85 engine aren't really big enough for much boost on a good running 5.3L and a returnless fuel system. On an E85 truck I'd go to 60's or bigger.
Old 01-23-2008, 12:24 PM
JB1
JB1's Avatar
Originally Posted by explorer5.0
E85 requires more fuel flow. Those 38(?) lb injectors that the flex fuel trucks have will support his power goals with gasoline; but to make that same power on E85, he will likely need 50-60lb injectors.
So if he bought the 5.3 with an E85 then if he wants to add an SC and run on gas...the E85 injectors and fuel pump wouldnt have to be changed?
what is the size of the gas injectors and E85 injectors for comparison?
Isnt the entire fuel system SS on the E85 or is it the same on both?
Old 04-13-2021, 09:07 AM
Registered User
Streetlegal42's Avatar
Default Swap?
My Tahoe is a flex fuel but found a low mileage LY5 can I use the LY5 and just put all my components and wiring harness on this engine and it work
thanks
mcfarlnd
02-25-2007 05:48 PM
SSRZ28
11-12-2006 08:05 PM
Snake Eater
01-03-2006 02:10 PM
sfd598
09-19-2005 09:01 PM
paw
18
10-05-2004 07:10 PM
Quick Reply: Is there any performance diff in the 5.3 LMG vs LY5
