Tech and info link idea
Old Jul 31, 2004 | 08:00 AM
  #31
marc_w's Avatar
Here's my handling, side to side leveling, and "custom" alignment spec info.
Old Aug 29, 2004 | 04:10 PM
  #32
SnakeOiler's Avatar
Can anyone point me into the direction of where I can specific technical specifications of the LM7? I have the bore, stroke, cam lift, CR, but I can not find anything about valve diameter, head air flow, or cam timing, etc.
If anyone knows this information or where I can find it, I would appreciate very much.
Thanks.
Old Sep 22, 2004 | 02:17 PM
  #33
Scream's Avatar
MOOBIES Moderator
Good reference for the differences between 4.8's and 5.3's
Old Oct 16, 2004 | 09:34 AM
  #34
one03sierra's Avatar
Formerly one92rs
Talking back window wind noise on ext cab's
here is what i have done to several ext cab's back windows to get rid of the wind noise. first i popped the window arm loose from the latch assembly>>
you can see it still touching here. i pop mine loose with a phillips head screw driver while opening the window.
then i pull it outward and have someone hold it. i drill a small hole in the base of the latch. then i drill a smaller hole in the frame of the door. enough for a screw to start.then i install a screw in the holes and tighten ever so slightly. it only takes about a 1/4 turn and then you are done.
i hope this helps. i can get some better pics if needed.
Old Jan 29, 2005 | 11:05 PM
  #35
SnakeOiler's Avatar
good article on wheel and tire fitment: http://carcraft.com/techarticles/3636/
Old Jan 30, 2005 | 10:17 PM
  #36
XLR8NSS's Avatar
Adkoonerstrator
This thread is in some serious need of orginizational help. Good tips and tricks but, we need a better way to organize them....Hmmmmm.
Old Feb 24, 2005 | 05:30 PM
  #37
XLR8NSS's Avatar
Adkoonerstrator
Well, here is a site with some OBDII code info that linhardt sent in. Hopefully in the future we have a better way to present all the info in here.
http://www.obdii.com/codes.html
Old Feb 24, 2005 | 11:47 PM
  #38
JSmith's Avatar
Hey, didn't I say I was going to do that at one time? Oh yeah I never got around to it.
Old Mar 1, 2005 | 08:20 PM
  #39
greenbuggy's Avatar
My contribution:
www.speedyoldtruck.com click "projects"
Lots of info for adding things to the older trucks (mine's a 72), some stuff on datalogging, electronics, ECM modding and some other things. Going to reorganize the site (again) soon to separate papers from projects...
Old Jul 16, 2005 | 04:12 PM
  #40
Ruffrider5.3's Avatar
Good site here http://en.wikipedia.org/wiki/GM_Vortec_engine
