Tahoe is pulling to the right...
Old Jun 9, 2010 | 10:52 AM
2k4tahoe's Avatar
Default Tahoe is pulling to the right...
have had 2 shops check the alignment, both places say its good.
now right front tire is balding on the outside
could i have bent something in the front end?
im running out of options
Old Jun 9, 2010 | 10:59 AM
meangreenburban's Avatar
If you bent something, the alignment checks would have seen it. When I bent a tie rod my truck was goofy. If it's pulling to one side all the time, it could be a stuck brake piston, maybe. I would say shocks b/c of tire wear but shocks don't make the truck pull. Could also be a hub bearing thats bad, anything that would cause drag. Hope that helps some, and good luck with it.
Old Jun 9, 2010 | 11:07 AM
2k4tahoe's Avatar
if it was a hub bearing wouldnt it make a grinding noise?
all the "bad" bearing problems i have dealt with or fixed were figured out cause it was real noisey.
i could change the shocks, hell probably needs it by now anyways.
if a stuck brake piston i should be eating thru pads on that one side more i would think.
Old Jun 9, 2010 | 10:11 PM
budhayes3's Avatar
PT's Slowest Truck
A "bad" tire, or tire with shifted belts, will cause a pull that won't show up on an alignment rack, and may wear the tire prematurely. Try rotating the front tires left to right and see if the truck pulls to the other side.
Old Jun 10, 2010 | 07:25 AM
A bad hub assembly, won't always make a grinding or a roar. The last one I replaced on my truck didn't make a sound, it just wore out a Nitto for me. But in your quest, you could very well have a bad hub, a bad tire or even a worn control arm. Check for up and down play in your hub, or have your tires Road Force Balanced to see if you indeed have a bad tire.
Old Jun 10, 2010 | 07:52 AM
2k4tahoe's Avatar
good to hear folks, i was thinking about rotating the tires in case of a bad tire.
Thanks Folks, will put these things to the test and report back.
torque wrench, you never let me down, thanks again!
Old Jun 10, 2010 | 10:55 AM
Glad to be of any help my friend! Just let me know whenever you need something.....
Old Jun 10, 2010 | 11:03 AM
2k4tahoe's Avatar
lol you know i will
Old Jun 10, 2010 | 11:25 AM
Vinniety's Avatar
Great point Bud!!! keep us posted.
Old Jun 10, 2010 | 04:20 PM
stevenc's Avatar
Are they good shops? It took 3 shops before i got my caster right.
