stripped oil pan bolt
Old Nov 27, 2010 | 04:49 PM
40series's Avatar
Default stripped oil pan bolt
the last guy i let work on MY ENGINE overtightened my oil pan bolt now its really stuck . Whats the best repair strategy
Old Nov 27, 2010 | 05:08 PM
Bumpers's Avatar
Vicegripps? If not you could weld a bolt or nut to it and get the old one out to replace it
Old Nov 27, 2010 | 05:23 PM
Mangled03gmc's Avatar
Baltimore Whore
If it is rounded off, use the next size smaller socket or even a standard on it, beat it on with a hammer.. Might mess the socket up, but should work.. Or take a chisel, hammer it in the counter clockwise direction towards the out side of the bolt.. Or like stated you could weld a nut to it
Old Nov 27, 2010 | 06:12 PM
Country Boy's Avatar
Senior Member
Is it the thread or head? I dont really know how you strip one.. but, if its the head, get these (sold at Home Depot or Lowes)
Old Nov 27, 2010 | 06:22 PM
outlawz2004's Avatar
Get it up to operating temp (or use a small propane torch)and use this to get it out.
Old Nov 27, 2010 | 06:24 PM
Senior Member
No need to get up to op temp. Its only a 10mm head and TQed to 18ft lbs (if installed right). hell, if its the 2 small ones, theyre 8mm and 132in lbs.
Old Nov 27, 2010 | 07:15 PM
Why not play it safe and get some heat in it first, makes it much easier. No use breaking the head off. A little head on a big bolt will snap easy if its seized that bad.
Old Nov 27, 2010 | 07:28 PM
Bumpers's Avatar
True story
Old Nov 27, 2010 | 07:29 PM
Coban's Avatar
Preeeettty sure the OP is talking about the oil pan plug....
Old Nov 28, 2010 | 03:23 AM
budhayes3's Avatar
PT's Slowest Truck
Heat will definitely help, run it and get it good and hot. I'd have a new drain plug ready to go though, and hope that it isn't cross threaded, or you'll either be drilling, re-tapping, or replacing the oil pan. There are oil drain plug repair kits available, not sure if they work on aluminum pans or not though...
