Starting issue...
When you hook the jumper cables up, are you going on the battery or some other place? I still think there is some reason all the power is not getting there. For example, if you are grounding the jumper cable on the block, it could be a bad ground wire. I am still interested in how hot the wires and starter are getting.
On the battery. Thats why I thought possibly the alt wasn't chargin very good, so we put a new one on and still the same problem. Only after its been running though. First startup in the morning or after its sat for a couple hours after being driven, starts like a brand new vehicle
Mine did the same thing a few years ago and it was a bad batt cable. You've addressed that allready. I'd check the connection at the starter, had one at work last week that would randomly not start, turned out the stud on the starter solenoid was loose inside the starter.
Sounds like we just need to go over all the connections and make sure everything is tight? Can we all agree on that? I just really don't think the starter is bad. Sometimes it will fire right up, but 95% of the time after its been running, its very hard to start
So, how bout this...
We were in a hurry when we moved the battery to the bed. Just used a cheap cutoff switch. Reading some on it today, it's only rated for 20 continuous amps and 125 surge...Am I just reaching for straws or could that very well be the problem?
