spark plugs
Old Nov 8, 2006 | 08:44 PM
Budman52tx's Avatar
Default spark plugs
i was planning on changing my spark plugs. which ngk plugs are the best? mods are in my sig and i only plan on heads cam and intake change for my big mods
Old Nov 8, 2006 | 08:49 PM
nightrunner's Avatar
Mr. Obvious
if you dont do forced induction or nitrous get stock heat range TR55
Old Nov 8, 2006 | 09:16 PM
Budman52tx's Avatar
what is the differance from the tr55 and the tr6 i might run nitrous later on but i will probly not do that for awhile.
Old Nov 8, 2006 | 11:29 PM
budhayes3's Avatar
PT's Slowest Truck
TR6 is a cooler heat range plug.
Old Nov 8, 2006 | 11:36 PM
For your application, what's wrong with the O.E. platinum plugs?
You wont see a difference between stock and the TR55 NGK's. IMO.
Jim
Old Nov 8, 2006 | 11:40 PM
The 160* T-stat only hurt your MPG's. The 160* stat is only good fo FI or medium to wild NA motors.
You will not see any hp/tq gains from doing this. How do I know, I've done it and lost 1 mpg on average. No gains in power.
I'm keeping it in because I already have a S/C to add.
Jim
Old Nov 9, 2006 | 09:47 PM
13 Second Truck Club
TR55's until you decide to run the gas then TR6's
Old Nov 9, 2006 | 09:52 PM
The TR6 plugs are a colder heat range. If you are spraying, there is no need for a lower heat range plug. The NO2 is already cooling things down.
Jim
Old Nov 12, 2006 | 12:01 AM
Budman52tx's Avatar
thanks guys tr55's it is
twake_410
Apr 14, 2016 09:58 PM
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
KleanKustoms
Sep 30, 2015 05:07 PM
