solutions for stuck jam nut on tie rod ?
That's everything I would suggest...if rust penetrant doesn't do the trick, then you'll have to heat it. If the tie rod gets damaged somehow, then you'll have to replace it and the nut with new parts.
http://www.kanolabs.com/
Guys, do yourselves a favour and try this Aerokroil. my buddy works on porches, says
they use it the night befor they remove exhaust system components
totally blows away anything I've used previously
ps a small pipe wrench is a great tool for stubborn tie rods
