solutions for stuck jam nut on tie rod ?
Old Oct 9, 2010 | 10:23 PM
40series's Avatar
Default solutions for stuck jam nut on tie rod ?
any solutions for ,'stuck jamb nut' on tie rood end?
Old Oct 10, 2010 | 03:44 AM
Blown06's Avatar
8 Second Truck Club
soak it in liquid wrench for a few hours, if not a day.
..........long *** cheater bar???
Old Oct 10, 2010 | 04:06 AM
Silverado53's Avatar
I agree, some penetrating oil and a wrench should do it. Put some muscle into it but dont bust your knuckles!
Old Oct 10, 2010 | 08:46 AM
scooter k's Avatar
Heat the nut with the torch.
Old Oct 10, 2010 | 09:45 AM
budhayes3's Avatar
PT's Slowest Truck
That's everything I would suggest...if rust penetrant doesn't do the trick, then you'll have to heat it. If the tie rod gets damaged somehow, then you'll have to replace it and the nut with new parts.
Old Oct 10, 2010 | 10:00 AM
sharpshooter's Avatar
dumb ? -
left handed thread?
Old Oct 10, 2010 | 10:04 AM
454navyss's Avatar
pb blaster is my preference, then heat it, and if all else fails use an impact....then a bigger impact, if a 3/4" drive impact doesnt get it nothing will, cut it off
Old Oct 10, 2010 | 12:27 PM
dlstewart01's Avatar
My tie rods are the same part # for left and right...
Old Oct 10, 2010 | 12:29 PM
scooter k's Avatar
both tie rods are the same...
Old Oct 10, 2010 | 12:53 PM
bow tie guy's Avatar
http://www.kanolabs.com/
Guys, do yourselves a favour and try this Aerokroil. my buddy works on porches, says
they use it the night befor they remove exhaust system components
totally blows away anything I've used previously
ps a small pipe wrench is a great tool for stubborn tie rods
