Sludge in my oil. alot.wtf
Old Nov 28, 2008 | 10:47 PM
Noah Burns's Avatar
thats why i started sea foaming my motor every other oil change once it got up over ~90k miles... i ran 15w50 mobil 1 in my 01 for the first ~60-80k miles... ran like a scalded *** ape. going to switch the '08 over to syn. once its due a change.
Old Nov 28, 2008 | 10:50 PM
00ChevyScott's Avatar
Wearin' da big hat
I'd never put anything thicker than 10w30 in my truck, but thats just me.
Old Nov 28, 2008 | 11:02 PM
Coban's Avatar
Oil is oil. Do you think with 15w40 vs 10w30 that my truck wouldn't run? I can get it cheap (read: free), so I run it. I'd run straight 30 if I could get it much cheaper...
The thickness doesn't really matter down where I live. If I pour 5 weight vs 15 weight, I can't tell a difference. In the north, a thinner oil might be worth it.
It only matters that you buy good, name brand oil. It doesn't have to cost a fortune though.
Old Nov 28, 2008 | 11:13 PM
GMCtrk's Avatar
I've been using dino oil - castrol 5w30 per the oil cap. But I'm thinking about switching over to the Amsoil oil and filter, it's synthetic and is rated for 25,000 miles or 1 year between oil changes.
Old Nov 28, 2008 | 11:19 PM
krambo's Avatar
Hows your crankcase venting system? PCV blocked?
Old Nov 29, 2008 | 09:19 AM
Avalanche2002's Avatar
There's something fishy going on. I put 200K on a 92 Grand Caravan using 5W30 Havoline oil and it still looked like new inside the engine (I had to replace the oil pan gasket at 190K).
Old Nov 29, 2008 | 11:01 AM
budhayes3's Avatar
PT's Slowest Truck
I used to run Havoline in my 85 MonteSS before switching to Mobil1, and my engine was spotless. Not sure if they changed their formula since then though. I have a feeling that the "tech" was trying to sell you an oil flush or something like that...that kind of sludge doesn't happen on a maintained engine unless you're using Crisco oil lol.
Old Nov 30, 2008 | 06:08 PM
Red04Silverado's Avatar
I would check that. Doesnt make sense why your engine is sludged if you use good oil and change it every 3,000 miles.
D1SCSS
Jan 25, 2016 10:14 PM
600 horses
Sep 10, 2015 11:01 AM
jrcabby
Aug 24, 2015 09:40 AM
05GMC4.8
Aug 7, 2015 09:55 PM
