Sludge in my oil. alot.wtf
Old Nov 26, 2008 | 11:50 PM
gmc55's Avatar
Default Sludge in my oil. alot.wtf
I took my truck to get thr oil changed today. It's an 04 5.3 with 110,000 miles and i use havoline 5w-30. Never went over 3,000 on an oil change and never abused. Guy that changed my oil comes and tells me i should think about changing my brand of oil because there was so much sludge in the oil pan when he took the drain plug out the oil would hardly come out. I've never had this happen before and now i'm thinking of switching to a synthetic. What do you all think. He said he had to take a screw driver to dislodge some of the **** to get the oil to drain. If this is true am i in for big trouble in the near future? I was thinking of running this oil about 1,000 miles and hope it cleans up a little then switch to mobile 1 but don't know about doin that with 110,000 miles.
Old Nov 27, 2008 | 12:02 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
cant imagine why sludge would show up all of a sudden, unless there is another issue and then it'd be a milky color
Flush it, just don't use water sorry, no use an engine flush, sea foam or whatever and change oil again?
Old Nov 27, 2008 | 12:10 AM
gmc55's Avatar
How do you use sea foam just put it in with the oil? If so How long do you let it stay in before draining the oil ?
Old Nov 27, 2008 | 12:17 AM
trever1t's Avatar
Instructions are all over the forum and there is a write up on tech too. Personally I've never used the stuff but if there was sludge in my engine I'd be trying to find out why and make sure I wasn't adding to the problem
Old Nov 27, 2008 | 12:41 AM
viciousknid's Avatar
Where's the Beef?
Valvoline FTW. haha
but i Agree. Sea Foam it and change oils.
Old Nov 27, 2008 | 12:43 AM
Coban's Avatar
Switch oils and quit wasting money by changing the oil every 3000 miles.
There is something fishy going on because I change mine whenever the light says (usually around 6000 miles) and when I took my pan off at 70000 miles there was nothing in it at all. I use whatever name brand oil is cheapest at the time but its usually 15w40. Diesel oil, it does have better detergents though.
Old Nov 27, 2008 | 12:46 AM
Where's the Beef?
I change mine about every 6k as well. thats when the light comes on. Never had a drop of sludge.
Old Nov 28, 2008 | 07:14 AM
You really need to Sea-Foam it to remove the sludge. Seafoam is about the best **** in the world to use. I got shelves of GM Oil Flush and it sure don't do as good of a job as Seafoam. Second...quit using Havoline. I see alot of Sludge here at work and 90% of the time it's in vehicles that use Havoline or Quaker State. They aren't really top-tier oils. The diesel oil as mentioned above does have great detergent qualities in it but use whatever you want as long as it's top tier oils. Don't go with whatever is cheapest at the Advance Auto line.
I change mine every 5000 and I use GM oil which is Mobil 1.
Old Nov 28, 2008 | 07:38 PM
ForcedInduction's Avatar
10 Second Club
Have you verified this? I would start there. Was the guy looking for an upsell? Engine flush or some crap?
Old Nov 28, 2008 | 10:20 PM
00ChevyScott's Avatar
Wearin' da big hat
you use 15w40 in your truck, WTF....
I'm suprized your truck still runs.
