Shortening dbw gas pedal
Old Apr 27, 2012 | 09:53 PM
HRV-LS1's Avatar
Default Shortening dbw gas pedal
Need to shorten the dbw pedal. Do I need to disconnect the electrical stuff thats on the pedal itself? Was wondering would the welding damage the electrical on the pedal.
Thanks.
Old Apr 27, 2012 | 10:12 PM
smokeshow's Avatar
Mod with training wheels
You'd try welding in that cramped space in the first place? Sounds like a pain in the ***. I would disconnect the connector to be safe...simple clip connector, you might as well.
Old Apr 28, 2012 | 06:39 PM
HRV-LS1's Avatar
The pedal is out of the truck. The electrical part is still apart of the pedal. Its located at the top of the pedal. Thats the the section I'm concerened about when welding.
Old Apr 29, 2012 | 12:20 AM
mcfarlnd's Avatar
Un-Registered User
Cant be too safe, I would try to remove the electronics if possible. Although the electronics aren't grounded to the pedal so, I don't see it launching unwanted voltage in the box. Either way I'm sure would be fine if you can't remove the electronics.
Old Apr 29, 2012 | 03:54 AM
smokeshow's Avatar
If it isn't installed, then don't worry about removing the electronics. Current will take the path of least resistance, and its not going to be through that circuitry if it has no easier path to ground.
Old Jun 6, 2012 | 11:56 AM
BR3W CITY's Avatar
I know this thread is like a month old, but fwiw I shortened mine. The rheostat/potentiometer doesn't like heat, and I had to take care to cover it from spark, and keep the beads short. Its not a big piece, and it heats up quickly if welded.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
thewrx
Oct 6, 2015 10:59 AM
turbo6c3
Oct 5, 2015 06:11 PM
sTNT971
Sep 26, 2015 04:22 PM
