short box bed conversion
Old Aug 15, 2023 | 10:52 AM
BoostedLS6.0's Avatar
Default short box bed conversion
Has anyone put a short box bed off a crew cab on a standard cab frame? I know the frame would have to be cut but just wondering where the cut or cuts would need to be made. Thanks
Old Aug 15, 2023 | 11:43 AM
strutaeng's Avatar
5 Year Member
You are trying to make a regular cab with a 5.6' (?) bed?!
Old Aug 15, 2023 | 12:41 PM
wretched73's Avatar
I looked into it and the cut has to be made in front of the rear axle. From the axle back is the same length for both frames
Old Aug 15, 2023 | 12:54 PM
smokinlmm's Avatar
Seems he wants a super shorty. I’ve seen a few dedicated drag trucks built like that.
Old Aug 15, 2023 | 01:38 PM
It's hard to find a good standard fleetside bed around. I found a shorty at the local junk yard thats in good shape. I've cut down lwb c10's before but haven't seen anything on this yet.
Old Aug 15, 2023 | 02:39 PM
shakenfake's Avatar
Shlumpt
5 Year Member
It is the same as the C10 basically
Old Aug 15, 2023 | 04:56 PM
smokinlmm's Avatar
There is a super shorty on Duramax Diesels that just broke the stock block record. Check it out.
https://www.duramaxdiesels.com/forum.../#post-1214149
Old Aug 15, 2023 | 05:03 PM
strutaeng's Avatar
5 Year Member
Old Aug 15, 2023 | 10:26 PM
adriver's Avatar
I know I've seen at least a couple ask about it on here in the past, not sure if they got it done. Doing it because you can't find a standard bed seems ridiculous. If you want to do it, then cool, but if that's you're only a reason...
Old Aug 16, 2023 | 10:13 AM
wretched73's Avatar
FYI...
https://www.performancetrucks.net/fo...3/#post5470073
