Shaving weight on a NBS?
Old Jun 4, 2009 | 10:02 PM
  #21
nonnieselman's Avatar
Originally Posted by tylerz71
You gave it to me. LOL its in my garage and Ive been contemplating cutting a hole in it but still trying to decide exactly how.
I think after I get some rims/tires I like and after I get a 4 wheeler I can deal with I wanna try some electric fans. if your still interested in doing that for me.
Anytime im home. Send me a Text, i got a new company phone and lost all my numbers.
Originally Posted by JoeGibbSilverado
low black99...memphis here, as i have been told, tylerz71, heat is the tranny's enemy, look into a decent cooler for peace of mind, its worth alot
A cooler can help alot!
I had 145k miles on my stock trans, it slipped 2nd gear one time and i put Superior Super servos in it and it lasted awhile longer. pulled it out (still holding just fine ) and put in a Built 60E. For another year i dealt with tons of transmission and Torque converter problems, Stock 80E cured them for now.
Also i believe the the EGR is disabled in his tune, its on my other computer so ill have to check when i get home. and i think i had all the setting ready for Efans in the tune also.
Old Jun 4, 2009 | 10:05 PM
  #22
tylerz71's Avatar
Removing the EGR won't help you performance-wise really, it will reduce some carbon build up in your intake and induction system though. EGR (Exhaust Gas Recirculation) is an emission device that reduces NOx emissions by recirculating exhaust gasses back into the intake of the engine. Higher NOx emissions are caused by higher cylinder/combustion temperatures. Believe it or not, introducing the exhaust gasses into the combustion chamber actually lowers cylinder temps since the exhaust gasses are cooler than the temperatures in the cylinders/combustion chambers. Some vehicles that are equipped with EGR experience problems when the EGR is non-functional...usually higher cylinder temps that lead to detonation. If the engine is properly tuned, not overheating, and the cylinders are free of excess carbon, EGR can sometimes be deleted without problem.
When I swapped out my 99 PCM for an 02 PCM, I no longer had EGR as the 02 did not come equipped with it. I removed the EGR solenoid and pipe, and plugged the holes for asthetics. I have not experienced any problems with pinging (knock on wood). (when the EGR valve got stuck closed on my 85 MonteSS, the engine started pinging like crazy until I put a new valve in and cleaned the EGR passages...different engine, different moster though...)
Oh I understand it more now. glad you filled me in. My intake has never been cleaned or anything, only my TB but I think Ill leave the stuff like that alone to keep from throwing codes and stuff.
Old Jun 4, 2009 | 10:09 PM
  #23
tylerz71's Avatar
Ok, will send a text.
  #24
we can take care of them codes
you ever get the gas tank sensor fixed? or whatever that was that time?
Old Jun 4, 2009 | 10:12 PM
  #25
tylerz71's Avatar
nope haha havent touched the gas tank since you scanned it. no problems so far but its at a shop gettin the fuel filter and front diff seals changed right now.
Old Jun 4, 2009 | 10:17 PM
  #26
ah ok cool.. keep you eye out on here for LS1 or LT1 Efans.. they usually run from $75-125..
Old Jun 4, 2009 | 10:22 PM
  #27
tylerz71's Avatar
alright but what about the harness? would I need to buy one (from Nelson) of those or will one off a camaro work?
Old Jun 4, 2009 | 10:28 PM
  #28
dont worry bout that
I can hook you up for cheap.
Old Jun 4, 2009 | 10:43 PM
  #29
tylerz71's Avatar
ah good. haha can you PM me your number because I sent a text to the number I thought was yours in my phone but I guess it wasnt.
Chewy07
Nov 14, 2015 09:46 PM
lsxperformance
Sep 14, 2015 10:53 AM
Gmc_sierra
Sep 13, 2015 10:02 PM
94f150
Sep 13, 2015 06:39 PM
bisqikss
Sep 8, 2015 03:35 AM
