Service Break Booster?
Old Aug 21, 2007 | 02:38 PM
Z71/99's Avatar
Default Service Break Booster?
I was wondering if anyone else had this problem and knew the solution maybe. Thanks in advance!
Old Aug 21, 2007 | 04:06 PM
There's a GM Technical bULLETIN ON THIS VERY SUBJECT (damn caps lock)...
My 2005 GMC had a Technical Re-call on the brake booster, so I took it in and we fixed it. But my 2003 Z71 didn't have the re-call. Shoot me your Vin # and I'll see what I can find when I come to work in the morning.
Old Aug 26, 2007 | 08:13 PM
Mr.Klean's Avatar
I have the same thing across my screen on my 2004 yukon..
Old Aug 27, 2007 | 07:43 AM
Hey you go guys, I'll post up the GM Reccomended Fix for this concern.
Subject: Service Brake Booster Message - keywords assist C0136 IPC pedal vacuum #PIT3568B - (07/27/2006)
Models: 2003-2006 Cadillac Escalade, Escalade EXT, Escalade ESV
2003-2006 Chevrolet Avalanche, Suburban, Tahoe
2003-2007 Chevrolet Silverado Classic
2003-2007 GMC Sierra Classic
2003-2006 GMC Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
This PI is being updated to add model years and to update the Condition/Concern field. Please discard PIT3568A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
The Service Brake Booster Message is used to notify the driver of a Supplemental Brake Assist (SBA) concern on vehicles equipped with rear disk brakes and a vacuum brake booster. There have been reports of the Service Brake Booster Message being displayed on vehicles which do not use the SBA system. During normal diagnostics, a DTC C0136 may be present in the IPC. This DTC will not be in eSI if working on a 2004-2006 utility vehicle, due to all utilities use a hydroboost brake systems starting in 2004. Also note that starting in 2005; the Silverado and Sierra no longer use the SBA on vehicles with rear drum brakes and vacuum brake booster. This message could be caused by the IPC not being programmed correctly. If the IPC was replaced on a previous unrelated repair and was not SPS programmed then this message will be displayed after the IPC does not receive a valid health signal from the SBA for 5 consecutive ignition cycles.
Recommendation/Instructions:
To correct this concern, SPS program the IPC. To check and make sure the vehicle is repaired cycle the ignition to off and run at less 5 consecutive times, delaying in each position at least 30 seconds.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Old Dec 27, 2021 | 05:12 PM
Aubra's Avatar
Registered User
Default Service break booster
Condition/Concern:
I have 2004 avlanche not equiped with break booster but displaying service break booster. I
Tried 5, 30 second ignition cycles did not clear. Any other tips thank you
thompson
Dec 27, 2017 06:48 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
RustyD
May 23, 2016 07:04 PM
Closer_2001
Sep 24, 2015 09:15 PM
fortune46x
Sep 16, 2015 08:18 AM
