Running HID Hi & Lo's with HID Fog Lamps
Old Apr 29, 2009 | 08:39 PM
lady3bglover's Avatar
Default Running HID Hi & Lo's with HID Fog Lamps
I know there may have been a thread or three on how to run HID Hi & Lo's along with HID Fog Lamps. If anyone has it, can you please post it up.
Thanks
Lisa
Old Apr 29, 2009 | 09:09 PM
onebad03's Avatar
this is the one i used on my old truck but havent had a chance to do it on my new one.
https://www.performancetrucks.net/fo...+headlight+mod
Old Apr 30, 2009 | 05:36 AM
Tootall's Avatar
one diode for the fogs . . .
. . . then ground out the lows for them to stay on when the high beams are on.
Meaning, splice/tap/cut/solder your ground wire for the low beam to the core support or frame. . . . then the lows will stay on when the high beams are on.
since you already have high/low/fog HIDs. You can set one relay up for each (makes them last longer) . . . and use 12v diodes between the relays.
Meaning no grounding crap from above
Corvette454l88
Sep 1, 2016 01:24 AM
stealthperf
34
Feb 14, 2016 11:35 AM
Bluchevypick
Aug 18, 2015 09:11 AM
pupi305
Aug 13, 2015 03:48 PM
Ketis
Jul 23, 2015 12:37 PM
