rough idle
Old Nov 21, 2004 | 08:01 PM
KeukaZ71's Avatar
Default rough idle
a few times lately, right after i start my truck it has a rough idle. one day i thought it was going to stall out. i turned it off and restarted it. then the idle was fine. almost felt like a few plugs weren't connected. the rough idle doesn't happen everytime. it is just here and there occurence. here are some things i think it might be:
- bad plugs
- plug wire
- fuel filter
what do you guys think? i did take my K&N off the other day and cleaned the inside of the throttle body. looks like the tube and hose clamps are on secure
Old Nov 21, 2004 | 08:50 PM
jow02327's Avatar
check you plugs mine was the same until i changed the plugs.
Old Nov 21, 2004 | 08:59 PM
hawiianpwr's Avatar
Definately put a new fuel filter in if you haven't in awhile. My girlfriends monte did the exact same thing and the fuel filter was the culpret
Old Nov 21, 2004 | 09:07 PM
creederado's Avatar
yes,
it wouldn't hurt to do an idle relearn as well after.
disconnect battery than reconnect
5 min running in drive sitting stationary,(after its warmed up)
5 mins in park
should help as well.
or maybe not.
Old Nov 22, 2004 | 04:02 PM
KeukaZ71's Avatar
it probably has been about 20k for the last time i replaced the fuel filter, and 30k for the spark plugs.
thanks for the suggestions guys, i'll give them all a shot
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
BlownHD
Oct 3, 2015 12:24 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Pimpinpete
Sep 8, 2015 07:39 PM
