rocker arm / valve cover issue
Old Nov 24, 2011 | 06:56 AM
03 BLACKOUTSSS's Avatar
Default rocker arm / valve cover issue
Alright, I've been running Harland Sharp 1.7 rockers for about 30K now. When I first installed them, the exhaust rocker on #7 was hitting the PCV shroud in the valve cover. Popped it off, did a little grinding, fixed. I have had to do that three times since then, each time, I need a little more clearance. Can I remove that shroud, put a breather on the valve cover and cap the line going to the intake? I'm getting tired of that ticking and having to fix it on a tuesday night.
Old Nov 24, 2011 | 08:20 AM
TXSZ66AVLANCHE's Avatar
I removed the baffle in the valve cover...and did this.
Old Nov 24, 2011 | 11:51 AM
SlickSierra's Avatar
What heads?
Old Nov 25, 2011 | 05:22 AM
the heads are 317s.
TxAvalanche - do you have a breather somewhere else in the system for crankcase ventilation? thanks for the pic man, hopefully its that simple. damn rocker ticking is annoying as hell.
Old Nov 25, 2011 | 06:45 AM
Here is where the breather in the valley cover, there is a write up somewhere about swapping to the LS6 valley cover and PCV system wuth part numbers. The truck coolant cross over can be used after you bend it a little for clearance, My crate engine came with the LS6 valley cover but think its around $68 online.
I just ran a hose from the top of the intake manifold around down to the valley cover
Old Nov 26, 2011 | 06:33 AM
thanks for the pics man. I don't think im going to take it that far. can I get away with slapping an old style sbc pcv breather in there?
The_W
Oct 28, 2015 09:00 PM
superchomper2003
Aug 26, 2015 09:39 AM
BigEd_72455
Aug 8, 2015 07:37 PM
maxspeed05V
Jul 19, 2015 07:08 PM
Mzay
Jul 6, 2015 11:03 PM
