Remove interior panels on 99 single cab
I am swapping the components in my 99, do you have to remove the door panels to get to the door speakers or is there an easier way. If they do have to be romoved, how do they come off?
You have to remove the door panel. Take out the screws the handle take the panel off around the door handle triangle piece in the corner near the mirror door lock indicater and pop the window and door lock switch off and disconnect the plugs from it then lift up and pull out.
Originally Posted by nathank
I appreciate the help, but I must say... punctuation would really increase the clarity!
Its been a long day at work.
pop off triangle piece on top front by mirror
pop out lock indicator
remove bolt behind grab handle
pop off and unplug trim piece on front of arm rest with window switchs on it
remove bolt inside opening for swich assembly
pop off trim piece around door handle
firmly pull up on door panel
pull out and disconnect wires for tweeter, heated seat switch, and bottom corner light
hows that i think thats everything
Yeah Im just lazy read it like you are reading a 3rd graders english paper and it will all be clear.
Its been a long day at work.hehe, understood! Tuesdays suck as bad as Mondays
Thank You Thank You
here is a tech artical from fsc that will help you get the panel off properly.
Pat
http://www.fullsizechevy.com/forums/...d.php?t=149287
Pat
Pat
Pat
Perfect. Thanks!
GXPJAY
Feb 13, 2022 08:15 AM
