Rear end swapping
Old Sep 21, 2014 | 08:58 PM
Leegreens's Avatar
Default Rear end swapping
Not much of a mechanic.
I want to build my rear end up. Been looking at swapping complete. My trucks a 2000 w disc brakes. I want a 10bolt w 4:10 & later pay for a eaton.
What truck should i get a 10bolt w 4:10 to swap right in?
Will i run into driveshaft issues i got a 2 piece steel truck is a ecsb.
Old Sep 21, 2014 | 11:41 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You need look at the 99-04 4x4 or the 03-05 AWD Silverado SS
AWD SS had 4.10 for sure with 2 piston disc brakes.
4x4 the 4.10's were an option. Disc came on all 99-04 models.
In 05 they went to drums Except the 05 SS With AWD and the Denali trucks up to 06.
Old Sep 22, 2014 | 08:14 AM
Txblue's Avatar
Are all 99-04 4x4 1500 rear ends 10 bolt?
Old Sep 22, 2014 | 08:51 AM
RS/SS 4.8's Avatar
10 Second Truck Club
Yes all 99-13 trucks were 10 bolt with the exception of the SS trucks.
Old Sep 22, 2014 | 11:55 AM
Leegreens's Avatar
Thank you. Is the gear ratio written on truck anywhere (like under the hood) or just follow vin.
Old Sep 22, 2014 | 07:38 PM
Leegreens's Avatar
Default Rear end
I found a 04 SS g80 posi 4:10 rear for $250.
Without calipers so i will have to swap mine. Will rust be a big issue here?
Does that sound like a good deal?
Old Sep 22, 2014 | 08:25 PM
Leegreens's Avatar
The SS had a 1 piece shaft i have a 2 piece. Will i run into any issues on my driveshaft fitting the rear end of the SS.
Old Sep 22, 2014 | 09:07 PM
green02's Avatar
In answer to your gear ratio question, it will be printed on the white sticker in your glove box. Assuming you still have the gears the truck originally came with. The ratio will be a gt or gu something i.e. gt5 = 4:10 iirc
Old Sep 23, 2014 | 05:25 PM
Leegreens's Avatar
The ss rear end had an aluminum driveshaft. Am i going to run into problems or will my 2 piece bolt up? My trucks a 3 door ecsb
Old Sep 23, 2014 | 11:53 PM
1FastBrick's Avatar
As long as its just a regular 1500 with 6 lugs and not a 1500HD with 8 lugs.
As mentioned RPO Tag is in the Glove Box. These are a few of the more common codes...
GU6 3:42
GT4 3:73
GT5 4:10
G80 Limited slip locking differential
Sounds decent if its in good shape
No. The rear end housing is the same, its the transmission and Transfer case that differ the length of the shaft or 2 piece Vs. 1
