Random Misfires
Old Jun 20, 2009 | 12:37 AM
greenz71's Avatar
Default Random Misfires
I have a 2003 5.3 it just started missing, and throwing a code po300, it has 96,000 miles on it could it be time for plugs or do I have other problems? It does it the most on startup whether hot or cold.
Thanks
Old Jun 20, 2009 | 06:26 AM
Truckshop's Avatar
plugs and wires will probably fix it if you are not having any running problems. otherwise it could be fuel related or plugged cats.
Old Jun 20, 2009 | 07:29 AM
budhayes3's Avatar
PT's Slowest Truck
Yea, do the basics first, plugs, wires, fuel filter, etc. Speaking of fuel, check and make sure that your fuel pressure regulator isn't leaking. Pull the hose off of the fp reg and check for the presence of fuel, if fuel drips out or there is a strong gas odor, the fp reg is leaking and should be replaced. (the fp reg is located in the center of the driver's side fuel rail)
Clogged cats will usually misfire under load, and the engine may not rev up past 4k if they were clogged or breaking down and blocking exhaust flow.
Old Jun 20, 2009 | 09:27 AM
greenz71's Avatar
No cats, I will check hose today. Thanks
Old Jun 20, 2009 | 11:23 AM
greenz71's Avatar
Now I get to show my ignorance, the hose you are talking about, is it the vacuum hose?
Old Jun 20, 2009 | 12:13 PM
budhayes3's Avatar
PT's Slowest Truck
Yep, it's a thin vacuum hose that goes to a round metal item in the center of the driver's side fuel rail
Old Jun 20, 2009 | 10:20 PM
greenz71's Avatar
No gas smell or presence, I will try plugs and wires.
Thanks
dantheman1540
Feb 24, 2016 09:56 PM
legerwn
56
Nov 15, 2015 10:21 PM
bearden86
26
Nov 15, 2015 03:58 PM
Velocity1
Oct 2, 2015 08:01 AM
CammedZ71
11
Sep 9, 2015 02:05 PM
