Raced a LT1 Camaro
14 Second Truck Club
Raced a LT1 Camaro
I was taking my g/f home last night and seen this 93-97 Z28 Camaro. It had what looked like 3in duals and a magnaflow muffler. I threw a rev at him in traffic and he threw one back. Traffic cleared up and we went from a roll 3 times, same results each time. He slowed down to 50mph, we took off right about the same time. I actually pulled him until his front bumper was at my back tire, then he started pulling about 75 and we both let off at 85mph and there was about a carlength between us. I was very surprised that I pulled him for a few seconds!
Originally Posted by greentahoe
That should really get you motivated to get that LS1 in there!! Youre so close... get to work!!
Here's my list of things to do:
-new bearings
-new rings
-FMS 221/221-.589/.589-113
-stall (2400-2600)
-new head gaskets/bolts
-FMS dyno-tune
-ARP rod bolts
-stock 5.3 heads with LS1 valves/valve job (I'll get better heads next year after the tax return )
I want to go all out, but just can't afford it, unless a miracle happens!
What's a good compression ratio for a daily driver LS1? I'm thinking 11:1-11:3...
Im running 11.3:1. I always have run 93 octane even when I had the 4.8 and it was fine but ever since it started to get 78+ outside temp Im getting audible detonation at like 1800rpms in 1st and thats it. I could just pull some time out but I just started to use a 80%-93 octane/20%-100 octane mix and it took care of it. You have e-fans and mine will be on soon and that will help if not take care of it. I plan on using the 93/100 octane mix even after I do the radiator/e-fans since Im running n20!
11.3:1 = slight detonation, hmmm, guess I'd better go with a 10.9:1-11.1:1. I remember reading somewhere in the internal engine section that one full point of compression is supposed to equal 2xhp. So I figure that uping the compression from 10.1:1 to almost 11.1:1 with ported heads, slightly larger valves should add around 25-35rwhp. Especially with a high lift cam which should add around 20-30rwhp alone. Sorry for rambling, just sharing my thoughts!
With the compression ratio being close to 11.1:1, shouldn't race gas add a little more power at the track? Or would more compression be needed to see any results? I know a few people that claim results using racing fuel with a stock compression of around 9.5:1, but I just don't see it happening...could be wrong though.
Racing fuel would obviously allow for more timing which would make more power. I wouldnt go too crazy with the CR as you could just run more timing when you want to go to the track and run race fuel.
I am running a very mild cam for a LS1 and with a bigger cam say 224/224 or something in that area I doubt I would be getting audiable det. Are you going to run a LS1 inatake. 11:3.1 with a bigger cam than mine should be trouble free. Im pretty sure that the e-fans Im doing will take care of the det Im seeing on just 93 octane. 100 octane is only .15-.20 cents more than 93 ocatane so its not a problem for me since the place I get it has 93 s well. I already had plans to do the fans,radiator,intake before I was getting det. Even though it should fix the probelm Im still going to run the 100/93 mix in case I want to spray!
