Put in a 5.3 and now towing is horrible
Old 05-03-2012, 02:07 PM
  #31
SnakeOiler's Avatar
Electric fans, so are they:
1) working
2) working when they are supposed to
High coolant and high trans tells me there is no air flow. Maybe. There should be airflow to keep it cooler if doing 55mph, but check out all possibilities.
Old 05-03-2012, 02:22 PM
  #32
13 Second Truck Club
grey matter 04's Avatar
could only be working on low speed with only 1 fan working not high speed for both fans to come on
Check the trigger wires they could be swapped if this is the issue
Old 05-03-2012, 02:37 PM
  #33
nonnieselman's Avatar
possible wired backwards? blowing air thru the grill?
ive done that before and didnt check them until my coolant wouldnt go below 220 idling and the AC wouldnt blow cold. DOH!
i could feel air being moved but had to use a peice of paper to check and see which direction. Swapped the wires and VOLA.
Be something easy to check and rule out.
and if the fans are tryin to push air forward, theres no airflow persay.
Old 05-03-2012, 04:39 PM
  #34
azchevydude's Avatar
I will check on the fans. All is good driving around town and on highway its only when i am pulling a load and it is hot out that the over heat issue occurs.
Old 05-03-2012, 05:49 PM
  #35
lady3bglover's Avatar
Check the ground?
Old 05-03-2012, 06:23 PM
  #36
CC05's Avatar
I think the problem is that you're mixing up the gauges, and reading the trans. temp, when you should be reading engine temp. In all seriousness, I'd like to look at the tune, myself. Also, I'm guilty of doing what Nonnie said. Check that out.
Old 05-04-2012, 09:30 AM
  #37
Both fans work and are pulling air in. Nothing is easy
Old 05-04-2012, 09:37 AM
  #38
Mod with training wheels
smokeshow's Avatar
Exactly what changes did you make to the cooling system? Thats when it started, so I'd check out everything you changed.
Old 05-04-2012, 06:06 PM
  #39
That is the problem, I changed everything. Radiator, water pump, therm, overflow tank, cap, ALL hoses and added the tru cool 40k cooler. Then after a few months i added the E-fans.
Old 05-04-2012, 07:45 PM
  #40
Custm2500's Rude Friend
1FastBrick's Avatar
So did it start at that point when you changed all the parts or a few months later when you installed the E-fans???
Quick Reply: Put in a 5.3 and now towing is horrible
