Pulling heads
Old Aug 18, 2014 | 06:07 PM
N/ALS1's Avatar
Default Pulling heads
Does coolant pour out when you pull the heads off the 60 block?
Old Aug 18, 2014 | 07:00 PM
Jake75's Avatar
When u disconnect the heater hoses coolant will pour out and some will still be left when u unbolt the heads and it will fall out when u pull the heads off...just get some rags and compressed air to get it out the cylinder after u have the heads off
Old Aug 18, 2014 | 07:25 PM
oakley6575's Avatar
Yea there will be coolant still in the heads up against the head gasket. So once the gasket unseals from the head, it will **** coolant. Like mentioned above, just soak up the coolant with towels and then blow the cylinders out with air.
Old Aug 18, 2014 | 08:16 PM
N/ALS1's Avatar
Thanks for the info. Wasn't able to get to it tonight after work. Had to straighten up garage.
Old Aug 18, 2014 | 08:23 PM
Suburbazine's Avatar
Make absolutely certain you brake cleaner (preferably non-chlorinated) the head bolt holes then use compressed air with a small hose or long nozzle to blow all liquid out of the bottoms. If you happen to screw a bolt down on top of liquid, you'll probably shatter the block.
Old Aug 18, 2014 | 08:57 PM
N/ALS1's Avatar
Are GM MLS head gaskets reusable? Thanks suburbazine that's a good tip.
Old Aug 19, 2014 | 01:34 AM
No, they are not considered reusable since they have one-time-crush sections that allow them to seal perfectly when the head is torqued down. I wouldn't even use one that was dropped on the ground or had the box crushed.
Old Aug 19, 2014 | 07:06 AM
Atomic's Avatar
I have a gauge for that
I reused some LS9 gaskets before, worked fine...not that I would recommend that.
Old Aug 19, 2014 | 07:13 AM
N/ALS1's Avatar
Yeah I'll just buy a new set of head gaskets, cheap insurance.
Old Aug 19, 2014 | 11:16 AM
01silvy's Avatar
I always say better safe than sorry... It gives me a excuse to blow more money too lol
