Problem with intake swap
Old May 26, 2018 | 06:32 PM
PFIX's Avatar
Default Problem with intake swap
Sorry if this has been coverd in another thread, looked but could not find the answers I Need. My 01 silverado is in a friends shop getting a new 6.0 with the NNBS intake. Just got a text the new injectors I bought are too short and the PCV from the old motor wont work. Need opinions on using injector adapters, any negatives on fuel delivery, spray pattern? If adapters are a good solution can someone post a link to the correct ones?
Any suggestions on the PCV parts needed with NNBS manifold
Old May 27, 2018 | 10:11 AM
darkirish63's Avatar
Spacers will work fine with the injectors. Do you mean EVAP and not PCV?
Old May 27, 2018 | 12:34 PM
PFIX's Avatar
Ordered the spacers from JEGS, I asked about the evap and he said he that figured out. Appearantly the PCV on the 01 will not transfer to the NNBS intake. The technician doing the install works at a GMC dealer and is going to order the parts for the PCV.
Thanks for your reply.
Old May 29, 2018 | 10:59 AM
2002_Z28_Six_Speed's Avatar
I have spacers on my suv and no issues. people tell me to get the spacers at go on the top and not the bottom. i just got the new evap canister and mounted it to the new fuel rail. cut up my existing evap tubes for the connectors and used silicone hose to route it all. works great.
Old May 29, 2018 | 11:26 AM
MrHorsepowerLSx's Avatar
11 Second Club
I don’t understand your issues with the PCV setup, but the EVAP line on the NBS is joined with rubber on the side of the intake, just pull it apart and marry the NNBS evap line to the old plastic line and problem solved.
And what’s the issue with the pcv? There is nothing different in length or connection. Just hook it up from the valve cover to intake and good to go
nickleahy23
May 6, 2014 08:28 PM
Mr. Merk
Feb 26, 2013 04:51 PM
01WS6/tamu
Apr 22, 2012 11:10 AM
brodystruck
Oct 29, 2007 10:09 PM
10secondZ
Aug 30, 2004 08:22 PM
