NNBS Intake help.
Old May 26, 2018 | 05:46 PM
VandykeT/A's Avatar
10 Second Club
Default NNBS Intake help.
I’m putting a nnbs Intake on a 04 Denali with the 4 bolts dbw throttle body. I plan to mod my stock rails and use the stock throttle body from the 04. Do I need an adapter for the throttle body and if so where do I get it?
Old May 26, 2018 | 06:15 PM
10 Second Club
Yes on a 4 bolt to 3 bolt adapter.
LS Throttle Body Adapter / 4 Bolt Intake to 3 Bolt TB w/ Gasket
Old May 29, 2018 | 11:17 AM
2002_Z28_Six_Speed's Avatar
Just get the new square metal style rails. I got a set off ebay super cheap. If you poke around there is a 4/3 bolt adapter sold in black AL and you can't even tell its there!
Old May 29, 2018 | 11:29 AM
MrHorsepowerLSx's Avatar
11 Second Club
Buying those throttle body adapters make putting that intake on useless.
Why downgrade an upgrade by choking its inlet with a small opening?
OP search around for a larger 4 bolt DBW throttle body and make good use of the intake
I would look for a set of square rails also, you will save your self alot of headaches trying to mod your factory rails
ihdude
Nov 1, 2018 03:28 PM
Kaldar
Oct 13, 2014 07:32 PM
Mr. Merk
Feb 26, 2013 04:51 PM
teamblackandred
Aug 22, 2012 11:52 AM
Atomic
Nov 6, 2010 01:38 PM
