PROBLEM... i went from return to no return fuel system... FUEL GAUGE DON'T WORK RIGHT
Old Oct 31, 2010 | 04:52 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
Question PROBLEM... i went from return to no return fuel system... FUEL GAUGE DON'T WORK RIGHT
ok.. i have a 2003 chevy excab truck that i just converted to a crewcab and in order for the crew cab to work you have to have the gas tank from it.. here is the problem..
the 2003 excab was a return style fuel system and the crew cab tanks are ALL returnless and you can not interchange pumps the size is way different...
and it will read full when empty and empty when full... i think the return style pumps are a 90ohm and the returnless is like 200ohm maybe...
has anyone delt with this yet? cause this is real aggravating plus i will be putting a return style pump in my turbo truck here in the next few days and it has a returnless pump in it now... so i'm sure i will have the same issue with it as well....
Old Oct 31, 2010 | 05:48 PM
2004SSS's Avatar
canb you possibly just use the fuel level sender ( the float and wiring to it ) and make it work on the correct bucket?
Old Oct 31, 2010 | 05:52 PM
they WILL NOT interchange... but i have epoxied one on it to make it work for the time being.. but i want it correct..
Old Oct 31, 2010 | 06:38 PM
andrew383's Avatar
traveling mod
It can be changed with a tune...
Old Nov 2, 2010 | 11:16 PM
are you 100% sure?? just askin cause can get a different comp if need be
Old Nov 3, 2010 | 12:38 AM
Daryn's Avatar
Formerly darynC-10/23/10
cant use epoxy in a fuel tank or aroud fuel vapors. lol
Old Nov 3, 2010 | 09:54 PM
anyone have any other thoughts
Old Nov 4, 2010 | 06:35 PM
andrew383's Avatar
traveling mod
I have a locked/tuned ecm for my 07 silvy (returnless) that i put in my 03 tahoe (return) and the gauge red backwards..
You can use the returnless ecm but the fuel settings will need to be changed..Either way you'll have to change somethingin the tune...
Old Nov 4, 2010 | 07:09 PM
kbracing96's Avatar
It just need fixed in the tune buddy,
wrb002
Aug 31, 2015 12:00 PM
atxlt
Jul 20, 2015 11:06 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
rudvirus
Jul 15, 2015 09:31 AM
Nimoryan
Jul 5, 2015 03:50 PM
