Problem with hydroboost setup
Old Jul 11, 2008 | 10:13 AM
thunder550's Avatar
High on diesel fumes
Default Problem with hydroboost setup
Just got my truck running with the hydroboost conversion. I'm having an issue.
I got all of the lines, brake master cylinder setup, and p/s pump off a 2500HD truck. Problem is, when the engine is at low RPM (somewhere below 1100 or 1000 RPM), I have no power steering or power brakes. When it's over that RPM, everything works well. Is the 2500HD p/s pump geared differently? Did I not bleed the system well enough? Just a bad pump maybe? Are the pulleys from the regular p/s pump and the hydroboost p/s pump the same size?
Old Jul 11, 2008 | 10:17 AM
64CAMINO's Avatar
Pulleys are the same.
Old Jul 11, 2008 | 10:19 AM
64CAMINO's Avatar
just ran the numbers on the pumps, the same pumps also, just diff housings.
Has to be a bad pump, or swaped lines somewhere.
Old Jul 11, 2008 | 10:22 AM
thunder550's Avatar
The lines felt like they only fit one way...hmm...
Is it possible to swap housings on the pumps?
Old Jul 11, 2008 | 10:35 AM
64CAMINO's Avatar
Yes, you can swap the housing.
Old Jul 11, 2008 | 10:40 AM
thunder550's Avatar
Maybe I'll try that then....I'll put my stock pump back on with the HB housing and see if that solves the problem.
Old Jul 11, 2008 | 11:13 AM
64CAMINO's Avatar
just set the truck to idle at 1100.
Old Jul 12, 2008 | 09:01 PM
Definately check the pump. Let us know what you find out.
Old Jul 13, 2008 | 06:49 AM
howard quick's Avatar
Check the Hydratech website for a diagram.
But yeah...check the pump.
Old Jul 13, 2008 | 07:08 PM
MonteCarlo31's Avatar
X8,367,563 the pumps the problem.
