Preventative Maintenance Suggestion
Old Aug 13, 2013 | 07:33 PM
BleuII's Avatar
Default Preventative Maintenance Suggestion
I was wondering if there is anything that would suggested as preventative maintenance on my daily driven 2001 Silverado 4.8L 4l60e 234K . I has 3.42 gears, the Jegs Off Road y-pipe, electric fans, and a 140amp alternator.
Old Aug 13, 2013 | 08:46 PM
DUK713's Avatar
I changed my plugs, wires, brake fluid, power steering fluid, coolant, battery, air filter and PVC valve just to make me feel better more than anything. All were pretty cheap.
Old Aug 14, 2013 | 06:17 PM
BleuII's Avatar
Okay Thanks
Old Aug 15, 2013 | 09:43 AM
TXsilverado's Avatar
plugs, wires, 02 sensors, fuel filter, belts, water pump and grab the idle pulleys and give them a tug and decide if you want to replace them. run a can of sea foam through the tank (after the new filter), clean the throttle body. rock on.
Old Aug 17, 2013 | 01:09 PM
azchevydude's Avatar
I might go overboard but i replace radiator, waterpump, Tstat every 100k-120k.
Belts,brake fluid, battery, coolant every 3 years
Old Aug 19, 2013 | 06:31 AM
SnakeOiler's Avatar
Change the rear fluid, I'm sure it needs it.
Gadgetized
Oct 22, 2015 09:06 AM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
The_W
Oct 1, 2015 02:35 PM
Slammed silverado
Sep 28, 2015 06:14 PM
sTNT971
Sep 26, 2015 04:22 PM
