Does anyone happen to have the steering line thread sizes? I'm particularly looking for the Steering rack side. The pump on my truck is actually an 02 Camaro pump and it is M16x1.5 which I found but I'm trying to make an AN style power steering hose but having a hard time finding the rack fitting size. Thanks guys
Well after a stupid amount of research I've come up with this....
High pressure side of pump: 16mmx1.5
High pressure side of the rack: 18mmx1.5
Low pressure side of the rack: 16mmx1.5
Found all the fittings I needed at summit, to convert everything over to -6AN. I'll post pics after I build the lines. If anyone want part numbers let me know I'll hang on to them. All I know is power steering rated hose and fittings aren't cheap haha.
Lines are are built. Definitely alot tougher than your standard AN lines. Unfortunately I won't know how well they work until I can get the truck tuned, and started again to bleed the system. I'll get some install pictures also. The return line isn't anything special, just ran a pushlock AN to the rack.
