Possible water pump making chirping sound?
Old 08-30-2012, 08:23 PM
03sierraslt's Avatar
I came up with some crazy *** belt routings. haha. I should have taken pictures of each, you would have went WTF???
Old 08-30-2012, 08:27 PM
phasemaster1's Avatar
Ok cool Im also going to remove the AC belt and just check it, but still going to change pump.
Old 08-30-2012, 11:22 PM
My AC compressor, AC belt, and AC belt tensioner are only about 1 month old. Actually the water pump is the only thing spun by a belt on my motor that is over 1 month old.
Old 08-31-2012, 09:38 AM
swift700's Avatar
Do you have any aluminum pulleys? Mine chirps when the A/C comes on at first and when I let off after a hard run. It didn't do it before the aluminum pulleys. They are a little more slippery.
Old 08-31-2012, 11:00 AM
Yes, I have the T-MAC 8 rib setup through Leftcoast32. My water pump is making a bearing noise also, if I route a belt so that I bypass the water pump all sounds normal.
Old 08-31-2012, 08:39 PM
Never had a chance to try the new water pump....I broke the tab on the bracket for the alternator damb procharger. Going to weld the tab back on in the mourning. CRAP!
Old 09-01-2012, 07:46 PM
Well I can still hear the chirp sound. Now Im wondering if its just a exhaust leak...
Old 08-22-2013, 06:07 PM
Registered User
Zapata1053's Avatar
Mine started the day after I put my new serpentine. I removed my air conditioning so I know it eliminated that. I know for a fact that the water pump is making the chirping noise. And it only does it when I accelerate. So I installed a new water pump and it still does it
Has anyone been able to figure it out.?
Old 08-23-2013, 09:54 AM
03SuperSLADE's Avatar
I hope its not this but is your oil pressure also fluctuating at idle? I had a chirping sound and it was a failed lifter and my oil pressure was fluctuating at idle.
Old 08-23-2013, 10:09 AM
Mine was a belt causing the noise from the alignment being off a hair.
ullose272
08-05-2016 02:05 PM
Razor
12-01-2015 10:46 AM
06 4.8
08-21-2015 11:33 PM
silver-mod-o
07-27-2015 05:24 PM
Quick Reply: Possible water pump making chirping sound?
