View Poll Results: 6.0 heads or just springs
springs on the 4.8, everything else stock
30
61.22%
stock 6.0 heads with springs and studs
19
38.78%
Voters: 49. You may not vote on this poll
poll, going to play with the 4.8 a little. stock heads or 6.0 heads?
Guess I will be the stand out.
I would like to you do the 4.8 with the 6.0 heads.
Larger valves, larger ports, larger combustion chamber for higher boost level.
Would be interesting to see the before stock 4.8 numbers then the after head swap 4.8 / 6.0 heads.
with the stock block the 6.0 heads should show allot more power.
I'm torn. The worst part about the 6.0 heads is the poor mixing that may result from the 6.0 heads combustion chamber measuring 3.930" wide and the 4.8 bore being 3.780". I say put some good fuel in the 4.8 and see what it can take. When it blows the head gaskets, then put some ARP studs on the 6.0 heads and see what you can get.
I voted for just springs. I remember you did this before on a stock 4.8 but the valves were floating at high psi. This ought to be interesting with the bigger turbo and only the strength of the stock internals to hold you back. Give it hell
Banned
Originally Posted by parish8
looks like i will be down for about a month or so. i am going to toss the 4.8 in the truck and see what i can do with that. i expect it to be very laggy
my last trip to the dyno with the 4.8 it was completely stock. i was spining the wheels and floating the valves and got to just under 500rwhp. this time i will be hiting up a dynojet so that will fix the spining problem. now for the springs, this is just for fun. would you guys rather see a completely stock 4.8 with just valve springs or should i try some stock 6.0 heads with springs? if i do the 6.0 heads then i will stud it too. i am kind of leaning toward a completely stock 4.8 with springs.
i am not even sure if it will spool. should be interesting
.my last trip to the dyno with the 4.8 it was completely stock. i was spining the wheels and floating the valves and got to just under 500rwhp. this time i will be hiting up a dynojet so that will fix the spining problem. now for the springs, this is just for fun. would you guys rather see a completely stock 4.8 with just valve springs or should i try some stock 6.0 heads with springs? if i do the 6.0 heads then i will stud it too. i am kind of leaning toward a completely stock 4.8 with springs.
WELL WHAT IS THE DEAL WITH U'R BIG MOTOR.
he turned his engine into a giant plasma cutter with too much cylinder pressure.....http://www.1320video.com/gallery/v/2005/parishmeltdown/
