planning stages of my next setup
Old Feb 7, 2010 | 02:30 PM
silver-mod-o's Avatar
Hunt&Fisherator
I got your PM Michael and can't send replys from this phone for some reason... There should be two boxes. One with the small studs and nuts/washers and the other has the rest of the big studs. Maybe itll be delivered Monday.
I'm looking into either stepped headers, or just 1 7/8 regular headers, either way, 3" collectors are minimum.
I didn't really fall in love with the truck as much as the simplicity of it and the power, there's really nothing magic going on with it... Just an extremely well matched and thought out setup.
Old Feb 7, 2010 | 02:36 PM
LsxCody's Avatar
well good luck with ur new setup,im sure it'll turn out good, you got any pics of the rc
Old Feb 7, 2010 | 02:42 PM
Hunt&Fisherator
No, its a basic reg cab stepside 2wd truck, dark green paint and tan interior. Its been hers since she was in high school. Its very well taken care of. I'm trying to get mine cleaned back up and 'nice' for her again. We can't really afford to go buy a new truck right now since getting the house and land so this is the next best thing till next year probably.
Old Feb 7, 2010 | 03:06 PM
GMCtrk's Avatar
Oh brother. I wouldnt be surprised if my mailman never delivers it. The little box barely fit in my mailbox.
Ben what would you think of cam swap while were at it? Might as well do it at the same time right. No spring swap needed just straight cam
Old Feb 7, 2010 | 03:18 PM
Hunt&Fisherator
Shouldn't be a big deal we'll get you all fixed up. What cam are you going to?
Old Feb 7, 2010 | 03:31 PM
GMCtrk's Avatar
It depends what is streetable. Im looking for a max torque cam that will shift at 6400 to 6500 max. The one i specd for myself has 9 degrees of overlap.
Old Feb 7, 2010 | 03:51 PM
Hunt&Fisherator
Old Feb 7, 2010 | 04:47 PM
454navyss's Avatar
at least you arent getting rid of your truck. from the time i met you in VA your truck has been an inspiration to me. what did she run at her last track outing? pics of the new toy?
Old Feb 7, 2010 | 04:53 PM
BlackGMC's Avatar
Resident Retard
Originally Posted by silver-mod-o
Plans are as of now to do a simple stout Heads/big cam/intake 6L with a well built 60E, good 3800-4200 multi disk converter, and a Tru-Trac and probably 4.30 gears with a ladder bar setup. Looking for 12.0s on motor and then we'll see where the bottle will take me.
That sounds like a good plan! Personally i would just get a pull out 6L, and throw some heads (CR 10.5+ ) on it and a 228-232 sized cam, NNBS intake, headers like you mentioned and be done with the motor...
So which brand converter are you planning on going with?
Old Feb 7, 2010 | 07:03 PM
Hunt&Fisherator
With the 4.8/78mm/80E with stock converter it went 14.4s at 102 first pass was 14s, and the last pass was 14s hahaha the damn thing couldn't een do a burnout.
Looking at either a PI or Circle-D converter, depends on who gives me the best deal basically. It'll be a 9.5" converter. I may have to choose a higher stall speed if I buy one that's setup a little tighter for nitrous. Ill need it for the cam numbers I have floating around in my head...
