people with volant intakes
Old Jul 24, 2007 | 07:52 PM
GTOsRamairSilverado's Avatar
Default people with volant intakes
i bought a used volant intake but i think it may be missing some pieces. Can anyone tell me what the intake consist of. i think its missing something where the tube goes into the box, where the 3 small bolts go. i tighten the bolts tight but there is too much play and the small bolts go staight through the holes. Am i just not putting it together correct, or am i missing something.
Old Jul 24, 2007 | 08:47 PM
pbraxton's Avatar
did you put the screws through the MAF sensor then box then plenum?
Old Jul 24, 2007 | 09:14 PM
i havent installed it yet but i didnt relize that the screw were suppose to go through the MAF sensor. you got a pic of what that part is suppose to look like?
Old Jul 24, 2007 | 09:22 PM
pbraxton's Avatar
three screws through each hole on the MAF first, then a gasket the the box, then another gasket, then plenum. sorry no pics but thats all you need. no pics on the instructions either.
Old Jul 24, 2007 | 09:39 PM
well thanks for the info....... i think i understand how you are saying that it goes but i only have one gasket. do you think the other one is really necissary.
BTW if anyone has pics of what is mentioned above, please do show!!!!!
Old Jul 24, 2007 | 09:42 PM
pbraxton's Avatar
i only got one with mine(second hand) and i put it on the inside of the box between the plenum and the box. works fine for me.
Old Jul 24, 2007 | 09:45 PM
Where did you buy your intake? I bought mine off of jegs. Hes right three screw connect your maf then theres the gasket whick buts up against the intake box then on the other side another gasket which hooks up to the plenum. Kind of sucks using allen keys though. Its pretty easy besides that.
Old Jul 25, 2007 | 05:39 PM
are both gaskets the same ??? cus i only have one.
Old Jul 25, 2007 | 06:32 PM
Ya both the gaskets are identical. Do you have the down tube? If you dont get it. Thats why I bought it only real CAI.
Old Jul 25, 2007 | 06:40 PM
are you saying i should buy the down tube? or are you saying its not worth the money? i didnt really understand that last part.
