paging shark_g
Old Oct 1, 2003 | 07:01 AM
leochevy2001's Avatar
Default paging shark_g
Do you have a rollpan on your truck? I noticed that you have the Magnaflow cat-back and was wondering if you could post some pics of your exhaust so that I could see it with a rollpan. I have been considering this exhaust since Saturday when I read in the new StreetTrucks(sp?) magazine that it gave an '02 4.8 about 20hp.
Old Oct 1, 2003 | 07:52 AM
FILE's Avatar
Default Re: paging shark_g
I sure don't have a roll pan. 20 hp.....
Was this at the rear wheels or at the crank. In the April issue of SportTruck they did a before and after dyno run with this system and put out 12rwhp. BTW, this was on a 03 5.3.
Old Oct 1, 2003 | 09:17 AM
I really don't remember if the 20hp was at the wheels or at the crank. I was just skimming through it at the store and then I left, of course without the mag. I will check to see if it was at the wheels because I thought that was a lot of hp to gain from just a cat-back.
Thanks for getting back to me about having or not having a rollpan. I just wanted to see what it looked like with one.
Old Oct 5, 2003 | 01:16 PM
Shark_g - finally made it back to the store yesterday and found the article in the "StreetTrucks" mag. Well I read through it again and it really doesn't specify where those numbers came from. When the article talks about them though, it says they are "peak" numbers. I am guessing that is what they got from the dyno. Here are the numbers exactly: 20 peak hp and 23 ft/lbs torque.
Old Oct 5, 2003 | 03:02 PM
FILE's Avatar
Wow.. even if its at the crank that is a lot of power.
Old Oct 6, 2003 | 06:19 AM
Do you know the part number of the cat-back that you have on your truck?
Old Oct 6, 2003 | 06:37 AM
FILE's Avatar
Sure, the muffler part # is 12579
Preshr
Sep 6, 2025 09:15 AM
Stainless Works
Oct 8, 2015 12:01 PM
carid
Sep 10, 2015 09:07 AM
