P0410 - AIR System
Old Jun 17, 2007 | 05:01 PM
Ferocity02's Avatar
Default P0410 - AIR System
So I got this code awhile ago and just checked it. It was a P0410, somesort of AIR injection system malfunction. Thise code is fairly obscure and I don't know what to check first. I don't want to take it to the dealer and get raped for repair costs. I'm thinking it might be a faulty check valve or something. I had a similar problem on my Z28 and it turned out that one of the check valves was stuck closed. Any ideas would be appreciated. The fuse is fine. Thanks!
Old Jun 19, 2007 | 03:51 PM
2k4tahoe's Avatar
more than likely it will be the same thing that your Z had if its the same code. i believe that is a generic OBII code. not really sure what to do, possibly check the air filter?
Old Jun 20, 2007 | 09:26 AM
Usually it's a leaky gas cap. That code will set from a gas cap vaccum leak all the way up to a large leak in the A.I.R. Pump. So, remove your gas cap and retighten it until it clicks about 3 times, and that may fix it.
Corvette454l88
Sep 1, 2016 01:24 AM
noproblems209
Aug 10, 2015 06:57 PM
92SS Wagon
14
Aug 4, 2015 06:42 PM
Mzay
Jul 6, 2015 11:03 PM
