P/V clearance
Old Jul 9, 2008 | 11:02 PM
amadeospike's Avatar
Default P/V clearance
How do you check for piston to valve clearance using putty and what is a safe measurement?
Old Jul 10, 2008 | 01:21 PM
AdioSS's Avatar
12 Second Club
safe? .150 on the intake and .200 on the exhaust.
It is possoble to measure the clearance without pulling the heads off. You can even do it with any cam you want installed. You need a pair of lightweight checking springs and an indicator. Rotate the cylinder you are checking to 10* BTDC and check both. Then rotate to 10* ATDC and check both. That is usually around when the valves might touch the piston. If you want to be really safe, then measure at 5* intervals.
Old Jul 10, 2008 | 03:31 PM
mcfarlnd's Avatar
Un-Registered User
where do you get this said indicator? and springs? i guess i could search huh
zblee
Nov 11, 2015 12:41 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
LSX-81-SIERRA
Sep 5, 2015 02:51 PM
