oil pan replacement
Old Apr 6, 2008 | 12:59 PM
sv650lex's Avatar
Default oil pan replacement
Has anyone tried to replace there oil pan with the motor still in the truck? Also how tough was it?
Old Apr 6, 2008 | 01:02 PM
thunder550's Avatar
High on diesel fumes
If you're a 2wd it should be pretty easy. Remove the k-member from under the pan, unplug the oil level sensor (and oil cooler lines, if you have them), and drop the pan.
If you're 4wd it's more difficult...the front diff has to come out first.
spent21
Aug 19, 2015 02:37 PM
Ls3silverado
Jul 31, 2015 04:22 PM
05SilveradoSS
Jul 29, 2015 08:34 PM
jmarkway
Jul 18, 2015 09:23 PM
