Oil leak
Old Dec 8, 2011 | 04:44 PM
cwalker2006's Avatar
Default Oil leak
Has anyone ever had an oil leak from their head gasket? I'm asking because I have an oil leak on the passenger side of my truck. But if I idle the truck it won't leak. But if it sees any boost, somehow oil is getting on my exhaust manifold and smoking. But I can't see anywhere where the oil could be coming from
Old Dec 8, 2011 | 06:35 PM
Suburbazine's Avatar
It's certainly possible, but are you sure the valve cover isn't leaking? There isn't any pressurized oil flowing up into the heads that I know of so there shouldn't be oil forcing its way out the gasket.
Old Dec 8, 2011 | 06:56 PM
I'll check that tomorrow. I'm just pissed that I can't figure it out. I've already had to fix tons of oil leaks, replace the oil pan gasket, both valve covers, pushrods. They hooked up an o2 sensor wrong.
Old Dec 8, 2011 | 08:57 PM
terravast4's Avatar
it could be pushing out from the dipstick tube......
Old Dec 8, 2011 | 09:20 PM
It's not wet around there. it might be the valve cover cause it's in that area.
Old Dec 8, 2011 | 10:40 PM
Check torque on valve cover bolts.
Valve Rocker Cover Bolt 12 Nm (106 inch lbs.)
I generally up to 120in/lbs if I see seepage.
Old Dec 10, 2011 | 03:15 PM
It was the oil dip stock tube. Been taken off so many times the bracket that bolts to the head broke. Put a new one on and so far leak free!
69z-28
Sep 21, 2015 07:31 AM
726.0chevelle
Sep 12, 2015 09:24 AM
cousblake11
Sep 9, 2015 06:52 PM
mayko
Sep 7, 2015 12:24 PM
the owl
Sep 4, 2015 04:09 PM
